CCcam openbox s11
This topic is closed.
  • bobjones124
    • 5
    CCcam openbox s11
    Hi to everyone snd good afternoon.
    Please could someone explain how to get my box up and running. I have followed the threads here but cant grasp it. In fact it's sending me quite mad.
    I am trying to use the test cccam line that.s on the little booklet that came with the box. NO INSTRUCTION MANUAL
    Each time I go to update by usb it says cccam not found but I know its on the usb as I can see it when its in my pc. I've tried putting it in manually but no joy there. It's getting me down and making me ratty. I am so dissapointed with this whole thing that I am thinking of dropping it in the rubbish bin.
    I'm doing my best to fix the thing but not getting anywhere, any help would be greatly appreciated.
    Regards: Bob
  • darcu5
    • Jun 2011
    • 944
    file should say cccam.cfg
    also you can use the remote control and manually add it instead of usb.
    • bobjones124
      • 5
      Hi Thanks for replying. Yes sir I have tried using remote but says file not found. I formatted usb Renamed file as CCam.cfg and copied info from booklet. Any Idea where I'm going wrong?
      Regards: Bob
      • darcu5
        • Jun 2011
        • 944
        not theres a c missing from your file? CCcam.cfg, if you go to menu with your remote,
        menu
        network setup
        cccam client
        manage config files
        cccam.cfg
        blue = add
        then on the lines, cccam looks like C: host 1200 user pass
        protocol = cccam
        host = host
        port =1200
        user = user
        pass = pass
        yellow button will save the info
        then go back to manage cccam and it should be there, select it to place a tick and exit all the way, reboot the box and it should be working
        Am i allowed to put this? let me know if not and i will remove it quick sharp
        • bobjones124
          • 5
          Thanks again, I've been doing what you say but when I restart it and go to manage files it says its there but offline or not active even though I have pressed green and the tick is in the box. Could it be the server thats offline and my box is ok? I am trying to use test line from instruction manual.
          If I have got the box working ok please tell me what I must do to get a working cee line file. I will buy one if its not too expensive.
          Thanks for help
          • darcu5
            • Jun 2011
            • 944
            hi cant really talk too much about it on the forum, but it sound like the server is off
            • bobjones124
              • 5
              OK thx for helping, much appreciated.
              Will do some searching about.
              • mast
                • Nov 2010
                • 1027
                Hi
                Ive just answered your pm, let me know if that solves it.
                Regards
