skybox f3 help
  • scottbp1979
    • Jul 2012
    skybox f3 help
    Hi all,
    I wonder if anyone would be able to help me out, i have a skybox F3 that has shall we say been "upgraded" by another.
    My father in turn has got wind of this as is keen for me to lay my hands on one for him. i have since ordered a "standard" skybox F3 and i am looking to "upgrade" it myself
    can anyone point me in an idiot proof walk though that an idiot like myself can understand? i apologise for my newbie question but i guess we all start somewhere
    please help
    thank you
    Scott
  • AfyB
    • 144
    I'm assuming its the HD version.
    -Download the attachment
    -Transfer the attachment to a usb (preferably one that has no data on it
    - Plug the usb into the front of the receiver, open the cover on the right hand side of the receiver and you should see a usb slot
    - Within a couple of seconds you should see a message appear on the screen saying Usb detected or a similar message
    - Go to "tools", click on upgrade by usb, make sure the image file is selected and click upgrade, it will load the data up and a warning box will come on, click yes, make sure you don't try anything whilst it's upgrading or you could brick the box
    - Once the firmware has been installed, all you need to do is add the Cccam or Newcamd info, press menu, go to network, cccam client setup, cccam.cfg...The End
    • khartoum
      • Aug 2012
      pls any motorize chanell list
      • Scoobster
        • 22
        If the USB Method is nerving, then you also have the choice of using a Network Tool (software) to communicate with the box via GUI and simplify the process somewhat.
        Backup cline, backup TP_PROG etc.
        Google SKYBOX F3 LAN TOOL - then decide which method you prefer.
        • thedag89
          • Sep 2012
          • 5
          thanks for the help mate. i have one question though...is the attached file the firmware or the image? sorry for sounding stupid but im a newbie.
          • nibblitz
            • May 2010
            • 1300
            Originally posted by scottbp1979
            Hi all,
            Upgrade it do or achieve what? Have you tried just using it as it is?
            • divdem14
              • Dec 2012
              Thanks AfyB for the very useful post
              • liznpaul44
                • Jan 2013
                thanks AfyB
                • ventura580
                  • Jan 2013
                  • 4
                  hola mi skybox se reinicia al acabar de cargar los 100 numeros que salen al encenderlo. que puedo hacer?
                  • knights
                    • Oct 2012
                    Thanks AfyB
                    • Silvermist
                      • Feb 2013
                      • 8
                      Thank you AfyB
                      A very clear disscription but I do have a question about this
                      ''Once the firmware has been installed, all you need to do is add the Cccam or Newcamd info, press menu, go to network, cccam client setup, cccam.cfg...The End''
                      How do I do this please? this is where I get confused?
                      • princecarroll
                        • Jan 2013
                        • 60
                        Originally posted by Silvermist
                        Thank you AfyB
                        the f3 I have all ready had Cccam installed, go to menu ,network settings,press 6666 ,if nothing happens press ok, but cccam option should come up.Cccam cfg file, the sealion must be put in a cfg file, it should read Cccam CFG File,unless it it put in like your box wont be able to read it.you tube will show you how to make a cfg file.I hope this is allowed ,newbie myself
                        • DW190
                          • May 2012
                          • 1263
                          No its not and you will be a banned newbie if you continue.
                          • mrmehra
                            easy guide
                            Hi, i have a similar problem and need an easy guide to reinstall the firmware. thanks for any help
