is there a new channel list ???
Skybox F3 Channel list
Have a look at this one.
can u give the channel list downlink to me. after i download the file n the file can'n be open and extract or unzip.pls help meLast edited by rajes21; 21 February, 2013, 16:27.Comment
hello guys, i just installed a skybox F3, tried the above files, but no joy. just went to upgrade with usb and chose the scoobysnack file. that worked ok. however when i go to upgrade using a *.abs the system can't seem to find any file of that type in the usb stick. any help will be appreciated. cheersComment
I downloaded the files to see where you are going wrong:hello guys, i just installed a skybox F3, tried the above files, but no joy. just went to upgrade with usb and chose the scoobysnack file. that worked ok. however when i go to upgrade using a *.abs the system can't seem to find any file of that type in the usb stick. any help will be appreciated. cheers
The first 2 files are channel lists .dbs format (adult and without adult channels)
The last file is the firmware .abs format
What you need to do is unzip the files and put them on (not in a folder) a usb stick then stick the usb stick in your box and update by usb option, I will assume you will know what to do from there.Comment
thanks all my channels are scramble can you help ?Comment
