F3 wireless problem
  • mart2011
    • Jul 2011
    • 15
    F3 wireless problem
    Hi
    Have got a skybox f3 with the offical wireless dongle.
    It works perfect at my mates with plusnet broadband connecting wireless but when i take it home to my virgin media superhub is just refuses to connect
    Ive tried it on both security settings :
    WPA AUTO
    WPA2-PSK[AES]
    WPA/WPA2 ENTERPRISE
    The box is running 3601HD_wifi_0512.abs firmware.
    Cheers for any help in advance
  • vapata
    • Apr 2011
    • 39
    Skybox F3, wifi, connection
    I have the same problem, brand new F3 with Skybox WiFi dongle. Have tried everything and it will not connect. I'm with TalkTalk and I think they are somehow restricting connection. Looks like I will have to send it back.
    • ravdeol
      • Jul 2012
      • 18
      Hi Try setting up box in same room as router then move to where you want it.
      Originally posted by mart2011
      Hi
      WPA AUTO
      WPA2-PSK[AES]
      WPA/WPA2 ENTERPRISE
      • vapata
        • Apr 2011
        • 39
        Done that, Skybox touching router, 2ft away and 4ft away, makes no difference; wont connect via Ethernet either. I think it's something to do with TalkTalk and anti-piracy. It would be interesting to do a poll on what ISP's work with the Skybox.
        • ravdeol
          • Jul 2012
          • 18
          Virmin works fine
          • tommie
            • Oct 2011
            • 18
            My X3 works fine via ethernet with Talktalk but not wirelessly, suspect its something to do with their router??
            • grousebeater
              • Jul 2012
              • 10
              Hi Guys
              The F3 is bad for wifi I gave up on mine especially since I got the superhub cos the wifi signal on that is shite,but if you try use wpa2 psk not a mix of the two security modes and like said previously try set up in same room...
              I finished up using homeplugs purely cos I am not able to get a wire through my loft due to disabilities,the homeplugs seem to give a good signal and pleasant viewing..
              Regards grousebeater
              • vapata
                • Apr 2011
                • 39
                Nop, I tried a different router and it made no difference. No idea what the problem is but cant afford to waste any more time on this, so I returned it today for a refund. My advice is stay clear of the Skybox F3, M3 & X3.
                P.S.
                So what's the best cccam receiver for under ?125
                • alex123
                  • 832
                  P.S.
                  its you isp thats the problem not the box
                  talk talk is rubbish unless your near the exchange
                  • housefart
                    • Sep 2012
                    So wot gear you runnin an wots your ISP.
                    • coventry1966
                      • May 2012
                      • 20
                      I've managed to get the Skybox F3 working wireless with talktalk (router upstairs, F3 downstairs opposite end of room) no problem.
                      My mate has bought a box same place and he was struggling it could be something to do with the login key.
                      • coventry1966
                        • May 2012
                        • 20
                        An update, it may be due to the type of Encryption and or length of the password. I would try a shorter password (login key)
                        • pl1976
                          • Feb 2010
                          • 213
                          Having the same issues here works fine on my vm but not his tt
                          • P&D
                            • 2686
                            Hi make sure the router settings (in admin) are set on 2.5ghz & not 5ghz i had this prob with my v***** router
                            • pl1976
                              • Feb 2010
                              • 213
                              F3 wireless problem
                              How is it you do that m8?
