openbox s10 multiroom
  • muscleo
    • Oct 2011
    • 4
    Hi all, i have a openbox s10 and i want to link it round my home< what is the best method for this?
    also i have a quad lnb and i am considering buying another box so i can watch different channels at the same time, is this possible?
  • badboy1965
    • 191
    use the LOOP, below sat antenna,but means more cable works for me tm6800hd in living room,looped to s10 in bedroom, (carnt move motor from the bedroom so make sure your on a sat you all wanna watch)
    • nibblitz
      • 1300
      Openbox doesnt have an RF output so the only way of distributing its output is via HDMI or its Composite Video Output.. I'd say using a Wireless AV sender from the Composite would be the simplest option, using as many receivers as rooms you want to watch it in..
      If you have a quad LNB then you could connect 4 Openbox to the dish, and they would be able to watch different channels.. But for the pay channels they would each need their own subscription, as you cant normally share one sub to other boxes to be used at the same time, your provider would kick you..
