i have the openbox 10s its easy to set up , pictures fine, epg like all skybox/ openbox isnt very good, but for the money there fine, tried the skybox f3 it looks more modern and picture is good think i would give that a go as its newer box
thanks for replaying...
ive seen Skybox M3...
any good?
will the flashing be straight forward on these M3 boxes?
The M3 is same as F3, but in a much smaller box with an external power supply.. I have an M3, works perfectly fine..
Flashing is as just as easy as with any box, but there's no need to be concerned with flashing anyway if its all working ok, not at least until a fundamental update comes out offering improved features..
Just stick to putting a channel list on it, dont be flashing system firmware unless you're attempting to fix some problem or the new firmware carries some significant operating improvement..
