Skybox f3 problem
  • miesyah83
    • Aug 2012
    Skybox f3 problem
    Hi..i am newbie and new user of skybox f3. i'm having problem with my skybox f3. it scrambled after i use for the third time. the problem is there is no light at RJ45 connector. i think it cause the server offline and scrambled. Actually, what it mean? it's my skybox f3 is already damaged or it can be repair just by using software?
  • Scoobster
    • 22
    No light on the RJ45 Connector would normally not be causing the scramble, but it could be an indication of a faulty ethernet port.
    As a first port of call, I would rescan all the channels and see if this resolves the issue, otherwise you can check if the cline you have is active via the hidden menu.
    Network Settings> Network Local Connection > Press 9999 and the menu will extend.
    Then go to CCCam Client Setup and select 'Manage'. Check if this is set to "Online".
    If this is online then it is not a issue with the provider, you may need to check your ethernet cable, port or even router in that instance.
    • miesyah83
      • Aug 2012
      Hii all..i need your help. i still have this problem. my account on CCcam.cfg is offline. there is no connection on LAN. i have test with my friend skybox f3 and there is no problem with that f3.
      what should i do?do you think my skybox f3 still can be fix?
