Have put the image file and channel list via usb on the box and trying to put the cline on the box have copied the cline from my other box, the DHCP is off but doesnt read it off my usb, any help would be great...
Skybox help please
format the usb to fat32, use metapad/notepad to create your line and save it as CCcam.cfg exactly as that say... make sure it isnt cccam.cfg CCcam.cfg.cfg or CCcam.cfg.txt..
drap and drop it to your usb, plug it into openbox/skybox and go to cccam update by usb and update it,
Failing the usb way, using remote control go to menu- cccam and manage cccam, press button to add and type the details in.If it isn't broke, don't try fixin it..!!!
When you save the .cfg file in notepad make sure you Save As then in the "save as type" field select "All files". Then your file should save properly as CCcam.cfg
Edit:
arrgh, I hadn't pressed refresh on the page...I see the question was already answered.Comment
