I've tried it on the f3 with a few different firmwares as well as both usb powered and mains powered and can't get it working. Think I also read somewhere else that they don't work with the f3
Guys,
just to let you know, the Vonets does work with the Skybox F3. Once you have set the vonets up on your pc, connect to your F3, in network settings turn off Wifi & change to Ethernet enabled. Let F3 reboot & wait. Takes a few mins but it will connect.
However, I will say that the connection strength is not as good as using the official Skybox WiFi USB but the Vonets does free up the USB slot for recording if you power the vonets via mains.
I have tried a Vonets bridge with Skybox M3 and 2 different Skybox F5S receivers. It does NOT work on any of them. I confirm that I choose the correct network selection. The same Vonets bridge works perfectly on Openbox S10 and Spiderbox HD7000.
