anaonymousx 13-8-12 firmware??
  • armstrongstreener
    • Aug 2012
    • 45
    Have read ther is a new firmware from anaonymousx? does anyone have this? thanks in advance the firmware date is 13-8-12
  • McrRed
    • Jul 2010
    • 86
    Thought AnonymouSX had given up on openbox?
    Is this the same firmware with avatarcam added?
    • Manic01
      • 5117
      Just been on his forum and can't see it anywhere.
      • slugworth
        • Nov 2011
        • 1064
        kills genuine openbox on contact,corrupts the protection ic.
        avoid that one.
        A variation of the aug 1st file
        • slugworth
          • Nov 2011
          • 1064
          was old beta firmware released by a beta tester
          • shub
            • Feb 2011
            • 26
            FTAZETA
            maybe this...
            • monsur
              • 52
              help
              i up dated my openbox s10 and how it will not display anything
              just two yellow dots on the front display of the box
              can anyone help thanks!
              • slugworth
                • Nov 2011
                • 1064
                your stuck running clone safe firmware from now on.
                • ricardoamm
                  • Feb 2012
                  Is there any way to recover the protect IC trough software?
                  If it was corrupted, it should be fixed in the same way as well.
                  AnonimousX should release a fix to solve this
                  annoying situation.
                  • slugworth
                    • Nov 2011
                    • 1064
                    If you trace the history of anonymousx firmware you will see that is why he came up with it in the first place.He had an s10 with a corrupt ic and fixed the firmware to bypass the hardware check.
                    • slugworth
                      • Nov 2011
                      • 1064
                      Originally posted by ricardoamm
                      Is there any way to recover the protect IC through software?
                      annoying situation.
                      or at least release the tool to mod any firmware to bypass the problem.
                      • starmike
                        • Oct 2012
                        i did mine that 10 times before
                        download the rs 232 software, get a null modem cable
                        download firmware- then open program and click com port,then check include bootloader ,upgrade ,look for .abs image saved on you flash drive ,click next, then put on box,
                        read screen ...
                        • flatdish2
                          what firmware to download to resolve this problem????help me bro..huhuhu
                          • starmike
                            • Oct 2012
                            just dl the .abs file from,
                            SkyBox | SkyBox
                            or the AnonymouSX V2 FOR S10
                            and you will find the loader there too,with all help files
                            • ricardoamm
                              • Feb 2012
                              I was able to flash successfully with the AnonymouSX V2, but I want to revert again to the genuine firmware, which I can't. After the genuine flash attempt I got "--".
