Skybox f3 - scrambled -goes offline after a while
  • kingkong1
    • Aug 2012
    • 7
    Hi,
    I just got a skybox f3, and set up cccam etc. I connect via wifi.
    It worked well for a hour, however when i tried it next day it went from online to offline/login.
    I assumed it must be server side. So i contacted the provider and they reset it and gave me a new port and .cfg file.
    I updated via usb the next day and it worked. But then I tried again a few hours later and it was offline!
    The server guy says its not a problem at their side,
    Any one got any ideas, or know how I can check?
  • nibblitz
    • 1300
    Have you tried using a wired connection instead of wifi
    • kingkong1
      • Aug 2012
      • 7
      Hi,
      It's not really possible as my router is upstairs, and my tv is downstairs
      • camane007
        • 23
        Hi
        Try the last firmware Download / Software / Skybox F3/M3_Shenzhen Yojia Technology Co., Ltd.
        • nibblitz
          • 1300
          Before you start messing with firmware flashing (which always carries a risk of bricking your box) you should really try a wired connection first, to rule out poor wifi signal performace in your home from being the cause..
