Certain channels coming up as scrambled?
  • Charlesy
    • Aug 2011
    • 11
    Im having a problem with a good few of the channels such as the sky movies hd, music channels and sports plus more. A lot of the other pay ones work but a few like mentioned above turn up as scrambled. I dont think its the server cause ive tested three different ones and i have the same problem. I tried a couple of the channel lists on here and aj's up to date ones had them working for a couple of hours but they went off again. The weird thing is late at night around after 11pm they come back on for me again.
    So i dont know if its just channel frequency changes or something else because if it did have something to do with change of frequency why is it coming on late at night?
    Can anyone help me?
  • ramjet
    • 2995
    broadcasters dont change transponders in the manner you describe, they may do it once every now and again but over a week or a month or a year it tends to stay the same for most channels, and all transponder changes are announced on various sites anyway
    putting it simply, it doesnt change at night compared to during the day
    they either work, or they dont, and if they work for half a day and not the rest its a srvr issue which we cannot discuss here
    what I can tell you is that an emu like oscam can be set to turn channels on and off at set times of the day, or it could be they are cheating and allowing other peoples cards through meaning as those other people come and go then so does the access
    do not assume the srvr has his own stuff, like a card or cards, he may be piggy backing off somebody else, you know nothing about srvrs so its pointless you speculating about them
    either way I believe its a srvr issue and therefore is tabu on here which is why you shouldnt have posted about it
    • mast
      • Nov 2010
      • 1027
      Hi
      It might be the lnb. Ive got a friend who is experiencing similar probs and will also depend on wetther channel is on vertical or horizontal. Defo not a server issue in me m8s case but more likely the zinwell lnb.
      When people unscrew and screw in the sat cable without switching box off can/will damage lnb.
      Regards
