satmeter kill my openbox????
  • str8edgewarrior
    • Aug 2012
    • 5
    Hi,I was installing new dish using satmeter with the openbox s11.it worked fine first time picked up thor and found few channels.When used it again satmeter did not work went inside and display was gone on box.plugged out box and got to power up.Tried again few times with same results and eventually box was dead.I would have removed coax cable few times from meter w/out power box off.replaced 2 capacitorand tried loading serial but no luck.Does any one know what component went as i have found no answers to this unusual problem.The box has power as it sparks up a hdd thru usb.Thanks.Any suggestions no matter bad or good appreciated.
