.dbs and .abs file format
  • octalsys
    • Sep 2012
    • 17
    Hi. Anyone know where I could find out the file format for .dbs and .abs file. Header info, layout etc
    For anyone wanting to write their own channel editor where would you get this info.
  • slugworth
    • Nov 2011
    • 1064
    probably the channel editor sourcecode
    • octalsys
      • Sep 2012
      • 17
      wow slugworth....wasn't expecting that..full source code..thanks very much.
      I'm not a programmer as such, just learning, but should be able to extract the layout from this source. Thx
      • slugworth
        • Nov 2011
        • 1064
        templates
        alieditor uses script.ini files,based on the type of receiver you are playing with.If you notice the pull down menu gives you the option of loading template files.If you delete the script.ini file and load a template file,the program will make a new script.ini file to use.Enclosed is a few template files that were bundled with various releases of the program.Copy your script.ini to a save place before deleting from the ali folder.There is no template for the openbox s10 that I could find.
        • ahmedhefny
          • Jan 2013
          Yeeeeaaaaaaaaaaaaah AliEDITOR Source code i've been searching alot to get .abs Format Reader
          • slugworth
            • Nov 2011
            • 1064
            dismus b d'place
            • tadej81p
              • Feb 2013
              Cool thx
              • harijose
                • Apr 2013
                thanx its i've been looking for so long...
                • ryansifontes
                  • Sep 2013
                  Is anyone else having trouble opening the source code file?
                  I get the message, "not a valid RAR file"... odd. Any ideas?
                  • P&D
                    • 2686
                    download with a different browser
                    • ryansifontes
                      • Sep 2013
                      That actually did the trick. Sometimes IE sucks..
                      • ryansifontes
                        • Sep 2013
                        What program can I use to view the source code file? Do I use a hex editor?
