Newbie SkyBox F4 UK owner
  • Realz88
    hello there
    Just wondering if anyone can point me to instructions on how to setup a SkyBox F4 in the UK. I have purchaser a working CCCAM server .
    I have not found any instructions regarding this box, and I'm stuck with free to air channels. Trying to install the F3 firmware gives a "size mismatch" error.
    Any help will be appreciated.
    Regards
    Sean
  • pellonet
    • Oct 2012
    • 15
    Have you been able to input your sim provider data connection details, similar to the ones you have to use on a phone?
    I have contacted Yojia to verify that the F4 is compatible with UK mobile frequencies but have read elsewhere that someone has put a SIM in their F4 & got a signal level reading, just not sure that they were UK based.
    The current software for this model is downloadable from http://www.yojiatech.com/a/Support/D.../0921/247.html but I have heard that this only has the Asian satellite lists in it so you will need a separate channel list download (lots of local sources) for your chosen satellites.
    • iceman
      • 52
      Confirmed , watching sky sports now threw my tmobile contract sim , also tried tmobile pay and go and working , will edit details to try a voda phone chip later..
      Thanks,
      • iceman
        • 52
        Originally posted by Realz88
        hello there
        Regards
        Sean
        This is due to the USB stick you are using being unsuitable , I also had this problem . Tried all firmwares ... Changed USB stick and working With the firmware ... Upgraded f3 and f4 with relevant software with new USB
        • Realz88
          Thanks,
          can you please post details of the UK GPRS settings you used and the relevant network ?
          Cheers
          • shub
            • Feb 2011
            • 26
            Cheers
            GPRS Connectivity - Information and UK Settings
            • beggsy21
              • Sep 2012
              • 76
              Thanks,
              let me know how you get on with the vodafone sim m8, interested in purchasing this box to use in my holiday home where there is no internet available. does the mobile signal need to be 3g or would a standard gprs signal be enough? is there a slot on the f4 where you put your sim in or is it used through a usb dongle? thanks in advance for any help.
              • iceman
                • 52
                SIM card slot at rear and I don't think these are working with 3 g .. Think it's GPRS only
                • beggsy21
                  • Sep 2012
                  • 76
                  is the gprs signal good enough to prevent scrambling and pixelation?
                  • shub
                    • Feb 2011
                    • 26
                    no its not mate..
                    im facing scrambling n pixelation every few sec!
                    • beggsy21
                      • Sep 2012
                      • 76
                      i had a feeling that may be the case, cheers m8.
                      • shub
                        • Feb 2011
                        • 26
                        is there a way of fixin this.... any advice or help plss
                        • hotchef
                          • 8
                          Hi, I am thinking of buying this box the F4. Have you got it working? Is it fast on navigation and channel change?
                          Are you happy with the unit ?
                          • Realz88
                            hello there. its a fantastic box. i have not used the f3 so i cannot compare both. overall very satisfied with it.
                            • brendanmcerlean
                              • Sep 2011
                              • 83
                              so guys whats the verdict on the gprs signal quality and how much data per month??
