Can I connect my openbox without broadband or wifi?
  • colanbo
    • Oct 2012
    Hi Guys, I hope I'm not going over old ground.
    I have just moved house and have no broadband for at least 6 weeks (BT are really useless). There are no good wifi signals.
    I can connect my laptop with an internet dongle. Is it possible to transfer this connections to my openbox s11. I have tried to make a network bridge, but it doesn't seem to work. If anyone can help I will be very grateful. I can't imagen 6 weeks of having to talk with the wife, please help!!!!
  • CaptainCretin
    • Oct 2012
    • 75
    It should work, but only for FTA channels.
    • saayinla
      • 162
      Do you not have smartphone that has wifi hotspot? you can make use of that
      • beggsy21
        • Sep 2012
        • 76
        I can recommend 2 options, firstly if you have a smartphone (iphone 4 etc) use the personal hotspot option to create a wifi hotspot then log on from openbox to that. Alternatively if you have a windows 7 pc you can use a clever little program called virtual router Virtual Router - Wifi Hot Spot for Windows 7 / 2008 R2
        Once you are connected from laptop to your internet dongle connection then run this little free program to share the connection as a hotspot, works for me!
        • colanbo
          • Oct 2012
          Sorry to be a nob, but how do I connect (logon) my Openbox S11 to a wifi network? I only have a Lan/Ethernet port on the back and I don't know any other way to connect.
          • nibblitz
            • 1300
            You can only connect an S11 to a network via its ethernet port... You could maybe use a wifi bridge, or home plugs, but you'll still be connecting the box via its ethernet port...
            • seamouse
              • 287
              flash a old router with dd wrt, that turns a router to a wifi bridge to connect the network part to a wireless signal
              MY POSTS AND ANY PM`S ARE PURELY FOR EDUCATIONAL AND LEARNING PURPOSES
              I AM FULLY RESPONSIBLE FOR MY OWN POSTS, MY POSTS ARE NOT CONDONED, MODERATED OR AUTHORISED BY ANY MEMBER OF STAFF ON THIS SITE AND I TAKE FULL RESPONSIBILITY FOR ANY CONTENT CONTAINED IN MY POSTS OR LINKED TO EXTERNALLY.
              • seanmckeown
                • 206
                With mobile hotspot or even using dongles I have never been able to connect to any servers using o2. Using 3 mobile has never been a problem. But in my experience, o2 connects ok and gives an ip address but won't connect to CCcam
                • colanbo
                  • Oct 2012
                  I've just managed to do this with S11 and XP with my dongle on 3 network.
                  I downloaded the program at connectify.me
                  You can then try the pro version for a week.
                  I then set the "Share Over and Sharing Mode" to my ethernet port and connected my laptop to the openbox via a normal ethernet cable and it works.
