I have recently got a skybox f3 hd box and im wanting to send feed a to an upstairs bedroom, i previously had a sky hd box with a aerial wire running up to the tv in the bedroom with a magic eye but on the skyboy f3 there is no connection to plug in the aerial wire. There is a connection called 'loop' but its not the same fitting it is same connection as the input from the dish, could i get a connector for this?
Or is the only way to get a twin hd adapter and the run a hd wire upstairs and do it that way?
If so can i also use the magic eye with the tv upstairs through the hd cable?
All advice appreciated, thanks.
