skyboy f3 hd loop out?
  • stevo88
    • Oct 2012
    • 70
    hi,
    what is the 'loop' connection for on the skybox f3 hd i assume it if a output for the box but the socket fitting doesnt fit a standard aerial with it is like a connection used for the sat dish, if i get a adapter can i run a output to another tv from the loop?
    thanks.
  • DW190
    • May 2012
    • 1263
    Originally posted by stevo88
    hi,
    thanks.
    The loop out is just a link through the box from the lnb input. It can be used on another sat box but not at the same time. One must be switched off/standby for the other to work.
    • stevo88
      • Oct 2012
      • 70
      could i feed straight to another tv from the loop?
      • aaa801
        • Aug 2012
        • 7
        The loop is not a tv signal
        it is a satellite data stream, DON'T CONNECT IT TO YOUR TV
        • stevo88
          • Oct 2012
          • 70
          ok so i guess the only option is getting a hdmi y splitter and then feeding the cable upstairs..
          • nibblitz
            • May 2010
            • 1300
            Using a basic cheap Y splitter wont work, they're only for sending 2 sources into a single hdmi socket.. You would need a proper 1x2 HDMI Splitter, and you'll also need to find a solution for using remote control on the other TV...
            Does it have to be HD on the other TV? Why not use a Wireless AV sender like I mentioned in your other thread? Or you could get a Wireless HDMI Sender if you must have HD, but they are pricey... But the advantage of using a wireless sender is they also allow for remote control..
            • stevo88
              • Oct 2012
              • 70
              hi nibblitz, i will have to use a wireless hdmi sender if i do that way as there is no scart connection on the box, if i used a hdmi cable is there no such thing as a hdmi magic eye?
              thanks.
              • nibblitz
                • May 2010
                • 1300
                You dont need scart to be able to use a Wireless AV Sender, you would use the Yellow Composite Video output and the Red/White Audio output on your box going into the AV Sender...
                If you use HDMI cable then the only way I can think of that will allow you to remote control is by using a Wireless IR Extender, somthing like this...
                [ame="http://www.amazon.co.uk/Marmitek-PowerMid-XL-infrared-extender/dp/B000GIXH42/ref=sr_1_1?ie=UTF8&qid=1350503027&sr=8-1"]Marmitek PowerMid XL infrared extender set: Amazon.co.uk: Electronics[/ame]
                Cost of HDMI Splitter, about 25 quid
                Cost of long HDMI Cable 5 to 10 quid
                Cost of Remote Extender about 25 quid
                Its gonna cost you about the same money as a decent 5.8ghz AV Sender, but going with HDMI will mean you get the HD quality on the other telly, so its worth doing if you can easilly route a HDMI cable through your walls/ceiling...
                Dont even consider a 2.4ghz AV Sender, theyre shyte...
                In my opinion Wireless HDMI Senders are still too expensive really..
                • stevo88
                  • Oct 2012
                  • 70
                  thanks nibb great advice there think iv finally made a decision...
                  how about this -
                  2 Port Hdmi Splitter Switch Amplifier 3D HDTV 1x2 1080P | eBay
                  Nikkai 5GHz Wireless HDMI Video Sender Kit - 1080p HD with IR/IRDA Remote Relay | eBay
                  then i would be transmitting a hd signal and also able to change channel from the other room?
                  • nibblitz
                    • May 2010
                    • 1300
                    Yep, them bits together should do the job very nicely for you... Not too bad a price for that sender... You might not get as good as quality as running a long HDMI cable, because I believe those HDMI senders use compression on the signal to squeeze it through 5.8ghz, so you might see artifacts on fast moving scenes, but I it should still be heaps better than Composite Video..
                    Might be a good idea to google for some reviews about that Sender before you part with your cash...
                    • stevo88
                      • Oct 2012
                      • 70
                      Apparently the quality can have some artifacts but overall apparently ok, if its really bad il just return it and get a cable.
                      Iv read a wireless modem can affect signal quality, my modem is in the living room and cannot be moved will this have much of a negative effect?
                      • nibblitz
                        • May 2010
                        • 1300
                        Nah, its the cheaper 2.4ghz Senders that can suffer from interference, the 5.8ghz models are usually ok as hardly anyother household gadgets operate on that frequency...
                        • stevo88
                          • Oct 2012
                          • 70
                          ok thanks for the advice its been great, hopefully the quality will be consistantly good!
                          cheers
                          • FREDDIE8239
                            Hi I have just got a skyboxf3 but want to use it on the telly upstairs and got told need another box and cable from box is that true
                            • sb18180
                              • Sep 2012
                              • 355
                              you need another cable from the satdish box to box connection dont work right you cannot split a lnb feed into two boxes(thats all loop does) each needs their own feed.
