F3 box question
  • P&D
    • May 2010
    • 2686
    F3 box question
    Hi all
    I have a question to ask about the slybox F3
    I have a box & its working great at my house
    decided to take it to my brothers house to watch the soccer to night
    Connected the box up at my bro's and could not get any channels all scrambled check the box & it says server login...
    Went back to mine & connected the box backup & all working fine
    My question is do the boxs work off your I.P address
    When i bought the box it came with a 12 month gift
    when i got it connected all the leads & it came on strightaway without any probs...
    Any helpi would be greatfull thx P&D
  • nibblitz
    • May 2010
    • 1300
    I doubt it... How did you connect it up at your mates, wifi or wired?
    • DW190
      • May 2012
      • 1263
      Originally posted by P&D
      Hi all
      The box works off its own IP given by the router if DHCP is enabled.
      If set to static you would have hadto input an IP yourself.
      If its working at yours, your router will have assigned it an IP. At your mates his router will assign an IP.
      When its all connected reboot his router. When the internet light is steady reboot the box and leave on a sub channel for it to log on.
      • dougm1970
        • Mar 2012
        • 103
        if your box has an i.p. of , say, 192.168.2.13 and your router is 192.168.2.1 then it will work....but if your friends router is 192.168.1.1 then it wont....so, like previous post, make sure that dhcp is on, that will automatically assign correct address to work with the router it finds on the network (assigned by the router)
        reading back i think i'm just repeating the previous poster
        • marty47
          • Jun 2012
          • 31
          hi mate it's most likely the line is paired to your address it locks on where it was originally set up some sellers do this to stop you sharing or cloning the line, it would explain the log in message you were getting and would also explain it working back at yours.This is common enough with plug & play boxes
          • dougm1970
            • Mar 2012
            • 103
            but a lot of people would have dynamic i.p.'s and turn routers off a lot...how would that work in that scenario?
            • marty47
              • Jun 2012
              • 31
              Hi Doug I'M one of those people you mentioned,can't explain the wherewithal of it but I do know skybox displays log in message
              if you are attempting a multiple connection on one line or if the line is only permitted server access thru it's original log in location.I know you would be more computer saavy than I but I do know this to be the case with certain sellers I've seen lines do it just can't explain how it's done mate
              • digger99
                • Dec 2011
                • 99
                I've never come across this scenario tbh, more that likely his problem was simply a reboot of his router didn't occur. As has been said already, it's also possible that DHCP wasn't set to ON.
                • P&D
                  • May 2010
                  • 2686
                  Wired mate thx
                  • P&D
                    • May 2010
                    • 2686
                    Hi Mate when i picked it up for the bloke i got it from
                    he had it connected to the tv he showed me it working all all channels ...
                    so when i got home i just connected all the wires & instant tv so i cannot see it locked to my I.P address or the line blocked....
                    DW190
                    Tried all this & still the same
                    I done a factory rest then without the net connected
                    installed all the correct software so the box should be running right ...DHCP enabled...then apply
                    Re-booted the router plugged the net in & rebooted the box
                    Still says login
                    Stumped at this & its not a problem but i hate it when something like this happens & cannot explain it
                    • marty47
                      • Jun 2012
                      • 31
                      Hi mate simplest way is to ask the guy you got the box off if the line is requesting keys from his server or if he has security measures in place all sellers have some form of protection
                      • Frogger
                        • Oct 2012
                        • 422
                        It could be banned for attempting multiple logins.
