2 openboxs
  • kerberos
    • Oct 2012
    • 5
    2 openboxs
    i have 2 openboxes and only one will work, the second box gets freeview for me but everything else is scrambled. if i take the box to a friends house it works perfectly!
    Any suggestions gratefully received, its my first post so please be gentle!
  • nibblitz
    • May 2010
    • 1300
    Is it the same server sub line on both and are you trying to use both boxes at the same time?
    • kerberos
      • Oct 2012
      • 5
      2 subscriptions and yes to viewing both at same time. Is there a post on setting up two boxes? i cant seem to find one. Thank you
      • nibblitz
        • May 2010
        • 1300
        Is it 2 different subscriptions? Or 1 subscription replicated onto 2 boxes?
        Setting up two boxes would be the same as setting up 1, but doing it twice...
        • kerberos
          • Oct 2012
          • 5
          Hi nibblitz,
          2 different subscriptions mate, the box from the front room works the back room does not. if i take the one from the front room to the back it works the other does not work in the front room. if i take it to my friends house it works fine so i am sure the settings are OK. i am assuming that i need to set it up differently for two subscriptions? The subscription provider does not know what is going on either!
          Do any ports need forwarding do you know?
          Thank you
          • DW190
            • May 2012
            • 1263
            Originally posted by kerberos
            Hi nibblitz,
            Thank you
            Possibly a clash of IP's.
            Check the ip's of both boxes, if they are the same that will cause a problem.
              Hi nibblitz,
              Thank you
              Is it a single feed from the lnd and is it split for the 2 boxes...............
              • kerberos
                • Oct 2012
                • 5
                OK, thank you for all your replies.
                i think i have sussed this, i am using MGcamd and there is an option for complex set up instead of single installation! Trying it now so will let you know if it sorts it.
                Kerberos
                • kerberos
                  • Oct 2012
                  • 5
                  Kerberos
                  Right, basically balls up on my part, had 2 single subscriptions instead of one dual subscription! On the plus side this costs me less. Thank you for all your replies.
                  Kerberos
