Skybox M3
  • murphyb007
    • Aug 2012
    • 88
    Skybox M3
    Hi All,
    Hoping someone can help me. I purchased two new Skybox
    M3 receivers and can seem to get the settings correct on the systems for the Antenna's. I have tried to duplicate the settings from my Skybox S12 and still cant get them to go? Can anyone advise me how to receive stations? Thanks in advance.
  • DOUGALMCD
    • May 2011
    • 3229
    Have you tried putting channel list on?
    • murphyb007
      • Aug 2012
      • 88
      HI, No not yet...I thought I needed the Antenna setting first?
      • DOUGALMCD
        • May 2011
        • 3229
        load list and check 28.2 first.
        • murphyb007
          • Aug 2012
          • 88
          I have checked 28.2 and have the lost loaded but is still not bringin anything through?
          • DOUGALMCD
            • May 2011
            • 3229
            when you loaded list did you reboot box and are cables all fine also dish?
            • murphyb007
              • Aug 2012
              • 88
              Yes, I re booted the box, I currnetly have a skybox S12, which is working fine, I just switched the cables over, dont understand why it wont go?
              • DOUGALMCD
                • May 2011
                • 3229
                Does the channel list show up on f3.
                • murphyb007
                  • Aug 2012
                  • 88
                  It does yes, shows up on the M3, same as the S12
                  • DOUGALMCD
                    • May 2011
                    • 3229
                    check lnb settings is set to universal (9750-10600)
                    check lnb power on
                    • murphyb007
                      • Aug 2012
                      • 88
                      Have it going now, I swapped the cable going in to the box to the other connection, of the two in the back, and it is going fine, Do you know were I would get a channel list for N Ireland? as in UTV rather than ITV? Thanks
                      • DOUGALMCD
                        • May 2011
                        • 3229
                        Glad your sorted mate all latest frequencies can be got at kingofsat.
                        • murphyb007
                          • Aug 2012
                          • 88
                          Thanks for your help, will take a look at it later, it's all very interesting this satellite stuff, got a couple of vu duos, bricked one, then learnt that the v2.0 can be unbricked, were as the other cant, do you know is this true?
                          • murphyb007
                            • Aug 2012
                            • 88
                            Hi again , does anyone know if you can get iplayer onto the skybox m3? Or what would be the best, cheapest way if doing this? Thanks
                            • Shady
                              Shite Link King
                              • Dec 2010
                              • 6404
                              no
                              cheapest way, probably raspberry pi with xbmc
