Skybox f3 + uk sky dish
This topic is closed.
  • sweepym
    • 6
    Hi chaps, im sure this has been answered elsewhere but I wanted to ask specific questions regarding my setup. I've got a new skybox f3 which I connected to my existing sky dish (which is working with an existing sky box) but I can't get any channels even the FTA ones.
    I know I need to scan, but I have a large list of satelites and am not sure which one to scan against, when I do hit scan it doesnt let me, cant remember the exact error but it wouldnt let me scan.
    Can anyone tell me
    1) If its possible to connect my existing sky dish to my skybox f3 to get FTA and should scanning 'just work' when I do this?
    2) If I can point my dish elsewhere to get other sats or is the dish too small to do so
    3) Do I need to connect a dish if I am using the other capabilities of the skybox f3 via a network
    4) There are references to a scooby firmware, is this any good or should I just use the FW from www.yojiatech.com
    Thanks for the help
  • amz
    • Apr 2010
    I am in the same boat here. I have received my Skybox F3 HD box and I can view all the FTA channels, but none of the $ ones.
    I've checked online for a dummy guide on what to do, but it seems to refer to CLINE and complicated stuff like that. There was a Youtube video on how to do things, but the interface is different too.
    Any help is much appreciated (sorry if asked multiple times before)
    • mtv1
      The Stig PT
      • 4413
      you need a sea loin google card share not allowed on here
      • sweepym
        • 6
        stop hijacking my thread, thats not what I was asking for!
        • nibblitz
          • 1300
          4) There are references to a scooby firmware, is this any good or should I just use the FW from [URL="http://www.yojiatech.com"
          www.yojiatech.com[/URL]
          Thanks for the help
          1. Yes, no problem, you need to scan 28.2e Eurobird/Astra
          2. Yes, no problem, you should be able to get a couple of other satellites with a sky dish...
          3. Yes you do
          4. The manufacturers firmware is perfectly fine, you dont even need to update your box at all if its working all ok...
          Have a look at www.dishpointer.com & http://en.kingofsat.net & http://www.lyngsat.com/europe.html & http://www.satbeams.com
          These websites will help you get the most from satellite TV
          • sweepym
            • 6
            3. Yes you do
            Have a look at www.dishpointer.com & KingOfSat - European Satellite Zapping & Directory & Europe, Africa & Middle East - LyngSat & SatBeams - Home
            excellent answers thank you for your help!
            • amz
              • Apr 2010
              Sorry for hijacking the thread... didn't mean to :-/
              • P&D
                • 2686
                Can anyone tell me
                Thanks for the help
                1) If its possible to connect my existing sky dish to my skybox f3 to get FTA and should scanning 'just work' when I do this? (No need to scan if you have a Channel list installed on the box)
                2) If I can point my dish elsewhere to get other sats or is the dish too small to do so (not sure mate new to this as well i'm sure u can)
                3) Do I need to connect a dish if I am using the other capabilities of the skybox f3 via a network (depends on what capabilities you r doing)
                4) There are references to a scooby firmware, is this any good or should I just use the FW from www.yojiatech.com (if the one on the box works ok leave alone)
                Silly question from me don't want to sound rude... but do you have a channel list on the box ???
                Post 568
                This will setup your channel list for 28E s*y (no scan needed all channels loaded auto)
                My apologies if this is not what you need
                • johndsam
                  hi, do you know anyone who do the see lion please as the one I got does not have some channels like nollywood, Ait and HITV showing. thanx
                  • dal13
                    • Feb 2014
                    • 28
                    3. Yes you do
                    Can i get some help please. Was I supposed to get a dish with the skybox f5s? Can it work without a dish? Keeps saying no signal
                    • mtv1
                      The Stig PT
                      • 4413
                      you need a dish mate
                      • dal13
                        • Feb 2014
                        • 28
                        dish
                        Last thing from me sorry. Can it be the same wire coming from my normal sky dish or was i supposed to buy the box with a dish?
                        • scotty1965
                          • Jul 2013
                          • 116
                          yes pal same wire from your normal sky dish ! dont forget to connect your skybox to you router !
                          scotty
                          • dal13
                            • Feb 2014
                            • 28
                            scotty
                            cheers mate. So do i connect both of the wires coming from normal sky box? Also I wouldnt be able to watch normal sky then would i?
                            • dal13
                              • Feb 2014
                              • 28
                              which one does it go into hoop or other one? Also why does it keep timing me out when I try to connect to router? will it not work if I dont connect?
