Skybox reboots by itself!
  • searius
    • 16
    Hi guys!
    I bought a Skybox F3 before 5 days and everything was ok.
    Now I have a problem with my skybox f3.
    It restarts by itself if I plug the ethernet. If I unplug the ethernet everything is ok.
    How can I resolve the problem? I tried to change the firmware but no go, the problem is there. Any suggestion?
    Thanks in advance!
  • sweepym
    • Nov 2012
    • 6
    happens to me as well, I think its just the skybox has not been thoroughly tested properly and there are bugs. Did you update yours to a firmware other than the one that came with the box?
    • searius
      • 16
      I tried changing it and the same result.
      How did you resolved the problem?
      • sweepym
        • Nov 2012
        • 6
        Haven't resolved it yet and it appears to be random. I didnt have the problem with stock firmware so I might go back to that and see if the problem persists.
        • searius
          • 16
          The problem is solved If I don't use c lines.
          If I use mgcamd everything seems ok. I will try another firmware and see what is going on.I will feedback any changes.
          • searius
            • 16
            I tried different firmwares but the problem is still there if I use clines instead of mgcamd.
            With mgcamd everything is ok!
            I tried 20/09/12 , 31/10/12 , 27/07/12 (factory image)
