openbox s10 help
  • baz007
    • Aug 2011
    • 40
    openbox s10 help
    hello everyone,
    my openbox started with the rebooting problem after like 8-9 months of use. So i figured it may be a bad channel so i unplugged the satellite feed installed a new channel list and it still reboots on $ channels? weird! what can i do to fix it?
  • baz007
    • Aug 2011
    • 40
    i decided to update the firmware and now its stuck on ON? i had to use the cable method with eerom upgrade software.Any ideas anyone? i may have to buy another box, any suggestions for the ?50-60 mark?
    • mast
      • Nov 2010
      • 1027
      Have you repaired it.
      Regards
      • wortho
        • 144
        get an f3 off amerzon for less than ?50 mate, but before that just try and get a firmware thats ok, im using one from last nov, not had that much bother with it might have to switch power off and on if i have left it overnight or something , no other problems, sorry in work so cant tell you the actual one.
        • slugworth
          • Nov 2011
          • 1064
          when you update firmware you have to tick include bootloader.
          • baz007
            • Aug 2011
            • 40
            hello everyone, i will give it a try again and make sure to tick include bootloader. Another problem is the USB don't seem to work now aswell! Any idea how i can transfer a channel list over without using a usb? really appreciate all the help everyone.
            • wortho
              • 144
              there is factory firmware on here somewere mate ,put that on and start from scratch
              • baz007
                • Aug 2011
                • 40
                Can't seem to find the factory firmware mate, any idea where i can find it?
                • wortho
                  • 144
                  sorry mate in work so blocked off a lot of sites, it was on here a while ago , think its on the manufacters download site as well
                  this might help matehttp://www.digital-kaos.co.uk/forums/f184/flashing-bricked-openbox-s10-214965/if the link isnt working its in post 208 on latest firmware , at the top forum. hope it helps
                  • slugworth
                    • Nov 2011
                    • 1064
                    transfer a channel list can be done via rs232 or lan.
                    Lan would be faster.
