cannot use yellow red and white to pc at same time as hdmi
  • Dan321
    • 12
    As the title says.
    I cannot plug the yellow red and white into my pc there is no picture showing, I have got my hdmi plugged in at the same time to my tv and that works fine.
  • slugworth
    • Nov 2011
    • 1064
    don't know the receiver model.
    s9/s10 had firmware that would do both at the same time.
    • nibblitz
      • 1300
      Yellow/Red/White into your PC? What input/capture device are you using on the PC?
      • Frogger
        • Oct 2012
        • 422
        Output mode needs to be set to RGB in display menu doesnt it?
        • Dan321
          • 12
          Hi
          I'm using an easycap device.
          I'm also trying not to lose picture quality on the pc.
          • Passive
            • Jul 2011
            • 30
            What's the model number??
            I'm using an X3, and output on the scart to a modulator works OK, even with the ouput setting in the menu on 'HDMI' for the main TV.
            • nibblitz
              • 1300
              Easycap devices are a bit naff really. What Capture software are you using? Have you tested anyother devices connected through your Easycap, do they work ok with that software?
              The best way to capture video from your box is to simply use its record to USB capability...
              • Dan321
                • 12
                Not sure about the model number, just easycap i think.
                I'm using adobe flash media server to stream to a server then watch on my phone.
                • nibblitz
                  • 1300
                  Does anything else work ok through your Easycap device? Like has been said before, the boxes do output AV at the same time as HDMI, so the issue isnt with your skybox/openbox....
