Openbox S10 Continually Dropping CCCam Connection
  • Del_RFC
    • 37
    I have a Openbox S10 which is giving me some grief.
    It will connect in to the router via homeplugs network then run for 10 mins then drop the connection. I then need to reboot the box or restart the homeplug and it kicks in again.
    Suspecting they were the problem I bought a new set of homeplugs and exactly the same thing is happening.
    To confirm it is defo the box I have another S10 which I swapped over now running flawlessly on the same connection.
    The cccam section shows as KO'd :-( when the connection drops. A quick reboot and we are back in business.
    Both boxes are running on the same firmware.
    Any ideas guys?
  • hooley
    • 470
    have you same firmware on both?
    • Del_RFC
      • 37
      Yes, what I think I will do is copy the version from the working box to the dodgy one and see how I get on.
      • ajax2061
        • 395
        tried it without the homeplugs ? they only as good as your rmains wiring after all
        I would try it with a long network cable or move it close to router just in case
        • Del_RFC
          • 37
          Copied the firmware from the working box and it has been stable for well over an hour now.
          Looks like success. Cheers
