skybox m3
  • crozier
    • Oct 2008
    • 5
    skybox m3
    i have 2 no problems,brought one for my son paid sub for mgcam set it up on my system all ok ie,talktalk. sent it up to him only fta no scrambled he got bt hub on his broadband any ideas please
  • mdt
    • 3034
    switch dchp on and off, apply then switch box on and off. talktalk and bt are different networks,regards mdt
    • crozier
      • Oct 2008
      • 5
      skyboxm3
      thanks mdt,. i dont have the box in front of me. im not sure about dcht which way would be the best to try to tell him over the phone mine are m3 his has got wifi but he has it hard wirred
      • mdt
        • 3034
        im doing this from memory(which is poor at best) as although i have 2 f3 boxs here there boxed up ready for shipping in the morning...press menu, scroll untill you see network ect, enter the network menu and on the left hand side goto to lan set-up at bottom, ok then at the top right it says dchp, scroll left then right to switch off then on and go to bottom and select apply to save. now put the box in standby and bring it out of standby. regards mdt
        • crozier
          • Oct 2008
          • 5
          skyboxm3
          thanks very much for your help. ill ring him tomorrow with your advise once again thank you for your time and help.
          • mast
            • Nov 2010
            • 1027
            Hi
            What mdt has said is spot on, the f3 and m3 once setup and disconnected will default to dhcp off.
            Once the box has got to the user dhcp will have to be put back on.
            Think this is the case with the S12 too but not sure.
            Dont think this was the case with the other openboxes.
            Regards
            • Paddi23
              • 36
              I had the same problem with my bthub it will be the dhcp is turned off
              • crozier
                • Oct 2008
                • 5
                skyboxm3 thanks.
                many thanks to you guys ie; mdt, mast, paddi23, for you time and help in getting me sorted everything is up and running thanks guys.
