problems updating m3
  • will8791
    • Nov 2011
    • 19
    ok i'm having a massive headache trying to get an update onto my m3 box, ive got the firmware, extracted it and popped it onto my usb hdd. when i pop it into the box and go to update by usb it says there is no .abs any ideas please also i can't get aj's list to work either
  • will8791
    • Nov 2011
    • 19
    sorry for bumping this but it's driving me nuts any help please
    • amzwag
      • Dec 2012
      • 17
      hi. what are you trying to exactly do? are you trying to install the firmware (operating system)?
      if you can explain, clearly as possible. i will endeavor to help you.
      cheers
      • mast
        • Nov 2010
        • 1027
        Hi
        Have you put the extracted firmware onto the root of the usb.
        Also what format is your usb drive.
        Regards
        • will8791
          • Nov 2011
          • 19
          put firmware on to the root of usb and tryed in fat and ntfs and still no joy, and yes i extracted the file using winrar and also extracted using 7-zip just in case there was something wrong with the extraction
          • mast
            • Nov 2010
            • 1027
            Hi
            Why do you need to update firmware, any reason for it as I would have thought it would have the latest firmware on it.
            Do you just need an updated channel list for it, if so try mine in my stickie its up to date up to 5 mins ago.
            Regards
            • will8791
              • Nov 2011
              • 19
              Originally posted by mast
              Hi
              Regards
              the firmware i have doesn't have youtube or youp**n on it also i ain't able to update the channel list without firmware for some up apparent reason ????
              • mast
                • Nov 2010
                • 1027
                Hi
                Well Id hazard a guess that if you are doing everything correctly and its not happening for whatever reason then think you might have to go the serial route.
                Regards
                • will8791
                  • Nov 2011
                  • 19
                  Hi
                  Regards
                  great thats what i was trying to avoid never done that before and don't have any serial ports on the pc im using
                  • intel
                    • Apr 2010
                    • 128
                    I would check if the file has been extracted properly by opening a dos box and then go to the root of your pen drive, ie:
                    d:
                    dir
                    that will give you the names of the files and folders on the root of the pen drive............the file will be something like:
                    F3 Youtube 03-11-2012.abs
                    If the file is not in the root then you will get the error like in your first post
