SKYBOX F3 ETHERNET PROBLEMS HELP PLEASE
  • kenchov
    • 27
    Hi guys.
    Got some serious problems here which i would really like some help with.
    Ive connected my f3 box to my skybroadband router by ethernet cable and im getting no connection just the orange light.
    Ive tested the cable and it works fine on ther devices...
    Do i need to do something in settings or on my router/broadband connection somewhere?
  • asim18
    • Oct 2012
    • 27
    Have you ever tinkered with your Sky router's settings? Do you remember ever turning off something called "DHCP", if not then it's on by default and that's fine.
    On your Skybox you also have to make sure DHCP is enabled under ethernet settings.
    Is the orange light on the skybox or on the the front or back of your router?
    • kenchov
      • 27
      yeah the orange light is on the front of my router.
      • kenchov
        • 27
        ive set the dhcp on now but its still orange
        • asim18
          • Oct 2012
          • 27
          It may just be orange because the Skybox uses 10Mb ethernet.
          Have you tried connecting to something? Try opening the youtube app and search for something.
          • kenchov
            • 27
            Yeah it seems to be working on that. Would that mean its fine?
            Why is the light orange?
            • intel
              • Apr 2010
              • 128
              The orange light is because its connected at 10mb - the light would be green if it was connected at 100mb, but thats not a problem
              If youtube is working then your connected to the internet, if your saying that none of the premium channels are clearing but the internet on the F3 is working then I would check your sea lion settings, username password port etc
              • asim18
                • Oct 2012
                • 27
                Yep that confirms it. Your connection is fine. It's just orange because the ethernet port on the skybox is 10Mbs. Nearly all other ethernet hardware, for example your typical laptops and PCs are capable of 100 or 1000Mb ethernet.
                The orange light is simply a visual indicator to show you that its connecting at a slower speed. Just in case you're troubleshooting slow speeds or wondering why a network device is slow. This way you don't have to login to your router to check the speed, you just instantly know by looking at the light.
