skybox f3 help - uk sky channel list? how do i install and add the line?
  • wakkaday
    • 148
    ive just ordered from ebay and want to set up...can anyone help me please
    i have the image to flash
    how do i install the uk channel list and where do i get that from?
    and where do i add the cline line details?
  • nibblitz
    • May 2010
    • 1300
    You dont need to flash an image...
    Wait until you get the box, then have a play with it, browse through the settings, its pretty intuitive, if you need a channel list then AJ's channel list from the stickies is quite a popular one.. Then if you get stuck ask for help..
    • digicon
      • 8261
      I would imagine most of the Ebay skybox F3's are already preflashed with the latest firmware the last 2 i had where anyway.
      • P&D
        • May 2010
        • 2684
        The both box's i got off ebay where already setup with the channels & firmware just had to add the sealion
        • wakkaday
          • 148
          ive been given a test line and how do i enter that?
          some of the information i have given is
          "c: xxx xx"
          do i need to enter the c:
          • jaws2
            • Oct 2012
            • 345
            if you do it on the remote then no, i found it easier with the remote so leave out C: if you use remote control
            • mark8393
              • 2305
              "c: xxx xx"
              Your test will run out before you get box. If it's a cline then just put it on USB and put it on box, loads of guides, but it's easy to do without guides, you sort of work it out when you go into menu, idiot proof box
