skybox f3 stopped at "load"
  • rkabishi
    • Jul 2011
    • 13
    can anyone help,i had this box for about 2 weeks ,try to put the channel list dated 8 dec 12,but after upgrading try to reboot the box ,it cannot reboot ,it stopped at load and does not do anything
  • ian597
    • 59
    try and reflash it
    • bigalan
      • Apr 2010
      • 34
      yes you will need to re flash the box with a rs232 null modem cable
      • rkabishi
        • Jul 2011
        • 13
        cheers m8 i did reflash it using rs 232 yesterday and it works and back running thanks
        • monthehoops1888
          • Sep 2012
          • 13
          Hi this has happened to my mate.If i reflash it using r2 cable can i then try and update the channel list once i get it back on or just leave it alone?
          • Frogger
            • Oct 2012
            • 422
            Use usb stick to make a backup of newly flashed working box first. Store backup on PC. Then attempt the ch list update.
            • Frogger
              • Oct 2012
              • 422
              How did you get on hoops?
              • jaws2
                • Oct 2012
                • 345
                iits always best to back up your box type thing, and its so easy to store it on line as well or on your pc, i just zip mine up and get it stored safe, if you have not got a pc with a com port a lot been thrown out these day as people upgrade, so if you see one its worth getting hold of one, with this world of re-flashing boxes its life saver, myself if new firmware comes out and its something i don't need then i don't update, thats just me, no point fixing want isn't broke kinda thing
                • ventura580
                  • Jan 2013
                  • 4
                  que programa se utiliza para reflashearlo? mi skybox esta igual
                    Only English speaking forum if you need any help.
                    • ventura580
                      • Jan 2013
                      • 4
                      to my it same thing happened, but install a backup and new firmware and still the same, anyone know of any solution?
