Skybox f3 HD want allow me to scan channel
  • afridisheffield
    • Dec 2012
    • 8
    Hiya people iv got a Skybox F3 HD . I have done a channel scan on the multiple satallite option as some channels were working a few days ago and now come up with scrambled. After it had scan, the box just froze. I turned the box of as it wasnt responding to the remote. Now i have found out that i cant run a scan at all. the two options are blanked out in the menu.
    Any help plz
  • ollie2012uk
    • Sep 2012
    • 39
    Any help plz
    If you go into the satellite list option are there any sats in there?
    • DW190
      • May 2012
      • 1263
      Any help plz
      Have you scanned a few times on multi sat as you may have filled the memory.
      • afridisheffield
        • Dec 2012
        • 8
        this what is says in the sat menu
        sky-uk
        diseqc=disabled
        diseqc1.1= disabled
        motor type= off
        • afridisheffield
          • Dec 2012
          • 8
          yes scanned a few times
          what would i need to do plz
          • ollie2012uk
            • Sep 2012
            • 39
            sky-uk
            diseqc=disabled
            diseqc1.1= disabled
            motor type= off
            does it have a green tick next to it? basically is the satellite active?
            • afridisheffield
              • Dec 2012
              • 8
              nope it dosent have a green tick
              • ollie2012uk
                • Sep 2012
                • 39
                well thats why its not coming up to scan! it needs to be active go on it and press ok to make active, then exit out from there saving it and then scan it
                • DW190
                  • May 2012
                  • 1263
                  If the memory is full you would need to delete some channels.
                  • afridisheffield
                    • Dec 2012
                    • 8
                    still no luck
                    • DW190
                      • May 2012
                      • 1263
                      You say you scanned on multi sat option:
                      Do you have a motorised dish?
                      Go into Installation
                      Satellite list
                      Place a tick againste 28.2e
                      Single satellite scan
                      Blind Scan
                      I'm assuming your in the UK
                      • afridisheffield
                        • Dec 2012
                        • 8
                        yes pal in the uk
                        • afridisheffield
                          • Dec 2012
                          • 8
                          Satellite list
                          Blind Scan
                          done that just scanning empty
                          • nibblitz
                            • 1300
                            load a channel list onto it
                            • afridisheffield
                              • Dec 2012
                              • 8
                              sorry pal new to this
                              what do you mean by load a channel list
