How to rename F3 M3 X3 Channel Lists Tut
  • mast
    • Nov 2010
    • 1027
    Hi
    So many people on my Channel list stickies thread keep asking on renaming favourite names when they are getting muddled up on using mine or any other channel lists.
    So thought Id just write a bit of a tut to help people out.
    Tutorial
    Menu > edit channel > fav edit > fav button > this will now open up fav/name on right hand window > scroll down to name you want to edit fav/name and ok.
    Right arrow to get to middle pane scroll down to pencil and OK.
    Red on remote to delete previous fav/name and rename via up/down and right left okaying chosen letters.
    Once done blue to ok name and exit > repeat as required.
    Its good to have the order of the list you want to follow, sometimes might become tedious if name already exists but you will get the drift on how to overcome that.
    I will add this to the stickies thread as well.
    If there is a mistake let me know so I can rectify it.
    Hope this helps people.
    Regards
  • DW190
    • May 2012
    • 1263
    I usually just delete the last letter if you get the name already exists then go back to it after the old name has been deleted. (saves putting all the letters in again)
    • mast
      • Nov 2010
      • 1027
      Hi
      Thats what I do just add any random letter at end and go back aftter but I didnt want to add anymore to the tut was getting a bit drawn but glad you have added it.
      Regards
      • nibblitz
        • 1300
        Thats a good guide Mast... I worked it out myself after a lot of frustration, but its really not that intuitive at all on the box, so your guide will sure help a lot of folk out to get the job done..
