Openbox hdmi
  • iosH
    • Dec 2012
    • 4
    Openbox hdmi
    Hi, I have an openbox s9 and the hdmi function doesn't work anymore the scart works fine does anyone know what's happened really miss the hd
  • nibblitz
    • 1300
    Is the HDMI output setting on your box still on a compatible setting for your TV, it might have changed. It can happen if you accidentally press the Vformat button on the remote.
    • DW190
      • May 2012
      • 1263
      V-Format button just below the centre of the remote control.
      You need to press it twice to change the format. (first press just shows the format your on).
      Press it twice and leave for about ten seconds. If still noting try again as there are a number of different formats.
      It can also be changed in the menu but you cant see it if your using HDMI and wont know if your on the right one if you use Scart.
      First make sure your HDMI is pushed fully home.
