Scrambled channels on skybox f3? And HD movie channels not working!
  • ammo06
    I recently updated my firmware on my skybox f3 box and updated my channel listing to A'J's channel list and now my movie HD channels do not work? any ideas???
  • nibblitz
    • 1300
    Do all your other $ channels work?
    • darcu5
      • Jun 2011
      • 944
      all hd channels? you could try checking the lnb settings are set correctly in menu sat set up, should be set to universal 9600 - 12000 (cant remember the exact numbers off top of my head).
      If you check the tp of one that is missing you can change to the tp under the lnb settings and see if the signal is there, if not then you can change the power settings to a different universal setting and see if it changes.
      Also i had a problem with one of my boxes that didnt get a few movie hd channels channels even though others did, even manually scanning the tp's didn't find them, i had to change to a different f/w or channel list (not sure which as it was that long ago and on an s9) in the end and that solved it...
      Can i just ask; why did you update the firmware?
      • yodi94
        • Dec 2012
        • 8
        i have this problem as well i updated firmeware on skybox f3 and my cccam and all files got deleted so i cant watch my $ channels anymore as they say 'scrambled!'. help?
        • P&D
          • 2686
          Hi do you have a backup
          if not then your knackered if you have no backup unless
          you know the person you got the box off
          • manuforti
            • Dec 2012
            I'd double check the network settings and ensure your network settings are correct. After a recent firmware update my settings were changed. The DHCP was disabled.
            Sent from my GT-I9100P using Tapatalk 2
            • P&D
              • 2686
              Hi lad's i'm sure if you update the firmware on the box
              it over writes all the file on the box ??? (maybe wrong)
              After the update the box is returned to factory set
              if this is the case all the important parts that the lad needs have been deleted & unless you have a backup image of the box with all the original setting's & the important parts
              Then you have a FTA box as when bought
              Unless you have a backup you back to square 1
              @yodi94
              Did you backup the box via USB ????
              If not where did you get the box from ???
              Thx P & D
