problem when adding sea lion via usb on skybox f3
This topic is closed.
  • hairyscotsman
    • Nov 2012
    • 21
    Hi there and i hope i am posting in the correct place..apologies if not.
    I have just purchased a skybox f3 and was watching freesat via it for a few days. I have now purchased a sea lion and am having problems installing onto f3.
    I am able to get into ccam client set up and upgrade with usb. I have formatted the stick to fat32 and cleared everything of it apart from my 3 sea lions. When i press upgrade via usb it brings up a box with 5 choices CCcam.cfg CCcam.prio and 3 others.
    My sea lions are cfg yet when i go0 to add and read it says Cccam.cfg not found yet it is deffo o the usb.
    Can some one please help .
    Many
  • rigsby71
    • Mar 2009
    • 676
    You can enter manually using the remote & type it in the various fields.
    I have never done it with a USB stick.
    Can't say much more to the nature of this.
    Other forums can go into it in more detail.
    • togznstyle
      • Dec 2012
      • 166
      hi there
      go into menu network local settings press ok, then go down to CCCam client set up then upgrade files by usb then take it from there hope that helps.
      laura
      Never eat yellow snow
      Don't forget to thank me
      TOGZ
      • togznstyle
        • Dec 2012
        • 166
        or manage files. am new to this to .
        TOGZ
        • nibblitz
          • May 2010
          • 1300
          What are the odds that your CCcam.cfg file is incorrectly saved as CCcam.cfg.txt
          • Shady
            Shite Link King
            • Dec 2010
            • 6404
            this is very likely imo and top marks to nibblitz for bringing it up..
            if it is the case do this
            How to Change a File Extension in Windows
            • DW190
              • May 2012
              • 1263
              Or just a .txt or even a Ccam.cfg
              It will be something trivial. I had one I entered myself with a , instead of a .
              • hairyscotsman
                • Nov 2012
                • 21
                Thanks guys it had a number 2 in the file name and now the lines have been accepted but its still scrambled. When i go to manage cccam.cfg it says they are offline.
                Do i need to add any more firmware as i have just used the box straight out the box.
                I appreciate all the help.
                • DW190
                  • May 2012
                  • 1263
                  Just make sure your DHCP is set to ON
                  • Quickblood
                    • Dec 2010
                    I was wondering what the hell is a sea lion and where do I get one but I just figured it out .
