Skybox F3/M3 - Will it work in North America
  • sberisa
    • Oct 2012
    • 6
    Hi guys,
    Skybox M3 or F3 is it compatible with IKS or Private $erver?
    Not sure if it have the following list of satellite?
    EchoStar 10
    EchoStar 14
    Ciel 2
    They are all from Dishnetwork
    Any help would be appreciated.
    Sam
  • slugworth
    • Nov 2011
    • 1064
    I think you should ask if it supports the lnbs/switches you use.You may be stuck using universal lnbs and diseqc switches instead of the dishnetwork provided ones.
    • lincsat
      • 1228
      AIUI, the primary market is Asia and South America. Obviously, they also work in Europe and I expect in North America as well. There are many options for LNB configuration and CAMs.
      • sberisa
        • Oct 2012
        • 6
        Thanks guys for fast reply.
        In North America to get satellies as mentioned above LNBs need to be circular lnb standard - 11250 mhz.
        Also not sure if skybox have north american TP or I should add them my self and any idea how?.
        Thanks again
        Samir
        • bbb_uk
          • 429
          Skybox.cc has TP lists which may help.
          According to Lyngsat the TP is 110o W. Can you see it on your list of TPs?
          Even if it's listed, it doesn't mean you can receive it as there maybe LNB/CAM issues as mentioned earlier.
          • slugworth
            • Nov 2011
            • 1064
            dishnetwork usually uses dishpro lnbs and their own type of switches to match.Don't know if those are in the menu,don't own one.
            • sberisa
              • Oct 2012
              • 6
              Hi Guys,
              Right now I have a Dreamlink HD on 110W & 119W (EchoStar 10 & EchoStar 14) using circular lnb standard @ 11250 mhz with diseqc 2.0
              I found SKYBOX F3_M3 that has American TP and can be loaded into receiver.
              Is that safe to do?
              I have attached the picture of the LNB that I am using right now also that file i found to be added on Skybox receiver.
              I also use Newcamd or IKS to load my private server purchased from a different site.
              I hope I made it clear, because I am new at this stuff and sometimes dont know how to explain stuff right.
              Thanks again for your help
              Sam
                This 1 plug and play in Emerica why bother with F3
                Lexuzbox / Az america F-90 HD 1080 DVB-C Receiver
                HDMI out-put
                RJ-45 port to internet sharing
                more free channel
                Specification:
                -Fully Compliant with MPEG 2 / DVB, 16/64/128/256 QAMreception 50Mhz to 750Mhz.
                - Fully compatible with Nagra.
                - Memory for 6000 channels.
                - 7 groups of favorite channels for Audio / Video.
                - Multi Language Menu (native in Portuguese).
                - Function to organize Channels (Encrypted, or TP Name).
                - Search NIT SCAN Frequency Simbol Rate and QAM Size.
                - Function as a manual search.
                - Timer function for Sleep / On / VCR Record and Channel change.
                - Supports AC-3 Audio.
                - Picture-In-Graphics.
                - Multi-Picture Function (Mosaic, 4, 9 16 pictures).
                - Zoom in / out.
                - Electronic Program Guide (EPG).
                - Channel Editor and Firmware Loader for editing / boot.
                - Tele text supported by OSD y VBI.
                - Total lock and parental control.
                - Data transfer: receiver-to-receiver with or without TV or PC-to-receiver.
                - 1 cable entry
                - UHF modulator.
                - Audio Output Left eDi~~~~~. - RS232C Interface for programming.
                - HDMI output of 1080p Full HD
                - USB input for UPDATES
                • Shady
                  Shite Link King
                  • Dec 2010
                  • 6404
                  That's a cable box sj.
                  Sent from my Motorola Colorado using magic.
                    Pardon me! Must be last night beer effect can see shites hear I will go to sleep now.
                    • randy32
                      • Mar 2013
                      Hi, I have a skybox f5 and trying to set it up. On echostar 10 and echostar 14. 110w, 119w does not show channel names or info. How can I get that information? Need help!! And also will Iks work on this box for me?
                      • reyesrms
                        • Mar 2013
                        where are skybox files for N.America?
                        • thegame17
                          • Mar 2013
                          Hi sberisa thank you for the skybox upload.Been looking for that one.
