New to Skybox F3 have some questions
  • elrasho
    • Jan 2013
    • 46
    Hi,
    Got my Skybox F3 installed but have a few questions
    1. I have two Sky cables coming from by Sky Dish. I've used both and get a picture with both but which one should I be really using?
    2. I can't get into System Setup, it's password protected but whats the password?
    3. When watching things at 1080_60p the picture stutters, but it's fine at 1080_50p. What's causing this?
    4. Is the HDMI cable that comes with the Skybox F3 version 1.4?
    Any advice or help would be greatly appreciated.
  • bbb_uk
    • 429
    Have u tried either the usual 0000 or 1234?
    You can use either of the sky cables, but given a choice I'd use the one that gave the strongest/best signal (if there is one)
    • elrasho
      • Jan 2013
      • 46
      Yep tried them, tried many different combinations but still no luck I need to go into the System Setup and change the audio so I get Dolby Digital through my AV.
      Both the cables give the same signal, what is the 'Loop' connection for?
      • mjon
        • 58
        Originally posted by elrasho
        Hi,
        Passwords try 6666 or 8888
        • nibblitz
          • 1300
          Just use one of them, dont connect both.
          0000, 1234, 1111, 6666 (or speak to your box supplier)
          Framerate mismatch causing stutter. UK TV broadcast are PAL 50hz at 25fps, 60 is for NTSC broadcasts 29.97fps (like in America)
          You dont need a 1.4 cable with a Skybox, the box has no function requiring a 1.4 cable.
          • elrasho
            • Jan 2013
            • 46
            Thanks for the information :-) the supplier doesnt know the password either , is there a way around this?
            • bbb_uk
              • 429
              Is it possible to restore defaults without it asking for password.
              If possible, you should know that everything is deleted including channel list.
              UPDATE:
              Just seen this thread which mentions another password you could try.
              • nibblitz
                • 1300
                Yea, send it back to your supplier then (as he's having you on) if its not any of the factory defaults then its been set by an end user (usually done on boxes sold with gifts) Or you could try flashing it via rs232, which will factory restore it, but any gift will be lost..
                • elrasho
                  • Jan 2013
                  • 46
                  How can I get my gift back if I was to flash it?
                  • nibblitz
                    • 1300
                    That is a "speak to your supplier" issue...
                    • DW190
                      • May 2012
                      • 1263
                      The supplier will know the password. He will have set it and wants to keep it to himself so you will have to return to him for future gifts.
                      If you bough from fleabay open a dispute "Not as Described". After all if a password has been set it is not new.
