DiSEqC
  • sirrias
    • Jul 2011
    • 24
    DiSEqC
    could someone direct me to a tutorial on how to set up the DiSEqC switch on an openbox s10, i will have to dishes sky dish on 28e and second dish double lnb 1 output on 19.2 and 13e thank you in advance.
  • darcu5
    • Jun 2011
    • 944
    on the box you will go into menu select sats, choose the 3 you wish to use, then satellite settings, and select a sat on the top line say 28.2 then select disq1 or 2 and the port number to direct it to 28.2
    so write the ports down on the disq switch beforehand if you can, then you know the numbers to match the ports
