skybox f3 losing connection too many times
  • johnwilliam1
    • 55
    i have had this sky box f3 about a week now, i find what happens it tends to lose the connection a few too many times especially when i am putting the channels in order for the euro sats, my other box a spiderbox does not lose the connection like this box, is there any fix for this.
  • darcu5
    • Jun 2011
    • 944
    is dhcp turned on? is it the internet connetion you are talking about or the box rebooting?
    • johnwilliam1
      • 55
      thanks for your quick reply, yes thats turned on, mainly losing connection from the internet, server online/ server offline, when i switch to the spiderbox i dont lose connection
      • adw1991
        • Apr 2012
        • 42
        i found that the my box hated newcamd and would only stay stable with CCam
        • nibblitz
          • 1300
          There's no specific fix as its not a common problem... Assuming you're using wired connection and not flakey wifi, try a different cable, try a shorter cable, try a different port on your router, test it with your box in a dmz....
          Lets also assume you're not using a strictly one box only line on 2 boxes at the same time, could it simply be your provider is crap....
          • johnwilliam1
            • 55
            thanks for the replys,
            i use one box at a time , i have a spiderbox which loops though to a skybox f3 with the same guy, one box on and one box off etc!
            my connection is inputted from the router straight to the spider looping throught to the skybox, i dont use wi-fi.
            • bbb_uk
              • 429
              Plug the ethernet cable straight from router into openbox without looping (ie totally disconnect spider) and see if that improves.
