skybox f3 and 3d
  • jonathan
    • Aug 2008
    • 69
    skybox f3 and 3d
    Anyone tried watching 3D channel on this?I get split screen and cant adjust settings of my LG tv
  • joe516
    • 1000
    f3 r ok 4 3d m8
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
    • jonathan
      • Aug 2008
      • 69
      yeah but i got split screen mode on my 3d telly and i cant adjust settings any ideas
      • DW190
        • May 2012
        • 1263
        Once your on the 3d channel you need to select 3d on you remote and select either vertical or horizontal depending on how the pic is split on the screen.
        • jonathan
          • Aug 2008
          • 69
          cant seem to do that
          • nibblitz
            • May 2010
            • 1300
            If your TV supports side by side 3D then it'll work if you enable it on your TV correctly. If your TV isnt side by side 3D broadcast compatible then it aint gonna work.
            • jonathan
              • Aug 2008
              • 69
              sorted now,i had to change video output settings on skybox -reboot-and then i could get split screen mode on tv
              • DW190
                • May 2012
                • 1263
                You mean you have a box with a 1080 output and were using something else?
