skybox f3 help
  • pspmixer
    • Jun 2009
    • 750
    skybox f3 help
    need some help setuping up a skybox f3 this first time ive used one of these boxs
    ive got the box wired up with ethernet cable straight into my sky router
    all my paid channels come up scramled there worked for 10 minutes then went off
    the line is fine as works in my openbox s9
    DHCP is on
    ethernet is actived in network on settings
    in rs232 function setup says twin protocol v4 with defualt settings in there
    and on my router instead of the light being green its orange
    hope someone can help me thanks
  • nibblitz
    • May 2010
    • 1300
    Have you got both boxes switched on and connected to your network at the same time?
    • pspmixer
      • Jun 2009
      • 750
      no one is switch off and other is on
      • nibblitz
        • May 2010
        • 1300
        On your Router, identify if your box is connected, identify the F3's mac address, then see if making your router assign a static IP to your F3 helps..
        • pspmixer
          • Jun 2009
          • 750
          dont know how to
          another way to and will try that last
          • nibblitz
            • May 2010
            • 1300
            See, we dont know if your box is even connecting to your router, or if your router is giving your BOX a unique IP.. Unfortunately theres not much else I can advise you try..
            When you get the time spend a while learning how your router works, because then you'll find troubleshooting any home networking connection issues will become a whole lot easier.
            • DW190
              • May 2012
              • 1263
              Or you could simply try the Utube function. If that works, you can safely assume your connected through your router to the internet.
              • pspmixer
                • Jun 2009
                • 750
                yes youtube works on it
                • Flaw3dGenius23
                  • Jan 2013
                  • 7
                  Connected my F3 box today and i also get the orange light on router instead of green.
                  • pspmixer
                    • Jun 2009
                    • 750
                    please help
                    • kendo75
                      • Jan 2013
                      • 16
                      Strangely enough I connect my f3 to a sky router and also get an orange light
                      • pspmixer
                        • Jun 2009
                        • 750
                        someone said to me is the router which is only feedon out 10 mb instead of 100 how do i change that then with sky router
                        • pspmixer
                          • Jun 2009
                          • 750
                          sorted it now
                          turn dhcp off
                          your ip should be top line
                          and on bottom line(dns alternate) you need to set it as 192.168.000.088
