If you want to move a dish with the openbox, then the most reliable i have found is the S9, apart from that, if it's for a fixed dish like 28 east, then they are all much the same.
I would be tempted for a s*ybox f3 rather than an openbox.
Go for a Skybox F3, or the M3 if you want a dinky little discrete box ....
The F3 and M3 use same software so settings and operation is identical, the F3 is probably the most popular box at the moment so lots of help & support, and compatible regularly updated channels lists are readily available..
