data dump
  • kano1990
    • 6
    data dump
    can anybody do me a data dump from thier working skybox f3 as i have tried flashing it with all available firmware but still no luck
  • seangraves
    • Sep 2012
    • 275
    data dunop
    hi mate can you explain ...ie wots it saying on box wen trying to load firmware can you put wot your software on box is on here because if its coming up mismatch ...were in the same boat the chanels are on box but no names in favourites ertc
    • kano1990
      • 6
      Basicially i bricked my box so had to flash it using rs232 lead. No matter which firmware i use i get a boot loop and the box wont load or come on thats why i need somebodys working firmware off thier box to try and fix it
      • mjon
        • 58
        Is this what you are looking for
        • seangraves
          • Sep 2012
          • 275
          file mismatch
          hi there mate sorry jumpin on your thread ...just bin lookin at your firmware ...my box keeps coming we file mismatch wen i load files on box ie channel list there yet no named favourites ..also gtried copying the one i got on my box downstairs ,,,it wont copy the channels that i organized on that box any ideas to solve this thanks
          • togznstyle
            • Dec 2012
            • 166
            SkyBox | SkyBox
            this has the latest firmware and if you dump all your data on to your usb then re flash then put it all back on you should get the channel lists.
            hope that helps.
            Togz
            Never eat yellow snow
            Don't forget to thank me
            TOGZ
            • seangraves
              • Sep 2012
              • 275
              reflash
              Originally posted by togznstyle
              SkyBox | SkyBox
              hope that helps.
              Togz
              hi mate wots reflash .....is thay just usb upgrade ,,,thanks if so tried that no joy still no names on favourite channels etc
              • togznstyle
                • Dec 2012
                • 166
                yes it is upgrade but we call it on here reflashing. try and put aj's channel list on and then do another reflash as it worked for me.
                togz
                TOGZ
                • kano1990
                  • 6
                  i cant update by usb, my box is bricked and stuck in loop boot
                  • togznstyle
                    • Dec 2012
                    • 166
                    Contact the person you got it from
                    TOGZ
                    • billy0911
                      • Dec 2012
                      • 18
                      ReFlash
                      togz
                      its my understanding that a reflash is when you put on new firmware via rs232 cable,
                      i used the dogsbollox and that works great on my F3.
                      an upgrade is when you upgrade your tv lists etc via usb.
                      if im incorrect im sure someone will let us know
                      Billy
                      • DW190
                        • May 2012
                        • 1263
                        This Image dump has a channel list embedded with favorites named for North West Region.
                        • kano1990
                          • 6
                          thanks for all the replys. ive decided to send the box back to the supplier and waiting on a replacement.
