skybox f5 satellite list
  • princecarroll
    • Jan 2013
    • 60
    My f5 contains only satellite's for Asia,when I do a blind search for eurobird/astra the results are missing alot of the HD options on channels. Is there a fix for this?
  • badboy1965
    • 191
    if you just want 28 east ,download aj,s channel list( most recent) and then add other sats as required
    • princecarroll
      • Jan 2013
      • 60
      will try that ,thank you
      • princecarroll
        • Jan 2013
        • 60
        As you see ,I am a newbie, where do I find this download and specifically the one you mentioned.
        • mast
          • Nov 2010
          • 1027
          Hi
          It in the red stickies. You can't miss it.
          Regards
          • princecarroll
            • Jan 2013
            • 60
            aj,s stickies ? help me out here bud, these
            don't mean anything to me. walk me thru this a little bit please.
            • SlyBoxBelfast
              • Jan 2013
              • 32
              In the main Satellite forums list the Stickies are the top threads in a box of there own. AJ's is usually top of the list as it is one of if not the best channel list. Its impossible to miss pal.
              • SlyBoxBelfast
                • Jan 2013
                • 32
                Better still.....
                • meatcandy89
                  • Feb 2013
                  • 4
                  I have the same problem as this guy, ive downloaded ajs channel list and can see where i can add a sattelite, but what is the right settings to add in for a sky dish?
                  • meatcandy89
                    • Feb 2013
                    • 4
                    i re-flashed it and picked up the sky ariel
                    • rowney7
                      • Feb 2013
                      im pulling my hair out here
                      hello all , im trying to setup my skybox f5 to watch all channels but im pulling my hair out trying to find out how to set it up sum 1 plzzzzz help :-)
                      • Shahinfarcry
                        • Feb 2013
                        You need to buy gift from eBay other people. Or you can search on Internet for free cardsharing.
                        • trukkerz
                          • Jun 2012
                          hi just had a skybox f5 - trying set it up but getting nowhere - cant put scooby snacks on cuz usb blocked (mismatch Error) it has firmware dated 01- 13 so if I put aj's on will it setup the settings for sky uk - thats all I need
                          A bit of a newbie :-)
                          • sb18180
                            • Sep 2012
                            • 355
                            yes it will
                            • badboy1965
                              • 191
                              if you click on openbox/skybox it means,you want info on that satbox, once on that page (the red section top of the page) is called the stickys it starts off with AJ,S updates and list,(the best around) to all newbies try reading this it will help you a lot and if after reading you get stuck,post your problem,and by the way if you put AJ,S channel list on your sat (only 28 east sly will be on your box) you have to add the rest,goodluck its also nice to say thankyou by PRESSING THE RED THANKS on the right hand side.
