Skybox f3
  • lammylee
    • Jan 2013
    • 4
    Skybox f3
    Hi can anyone help,
    I have a skybox f3, connected to the Internet via Ethernet cable when I switch the box on to watch tv I loose my wireless connection, this means I can't use any wireless device in the house while the skybox is switched on,
    when I switch it off,
    the wireless can be used again ?????? Any one please ????
  • lammylee
    • Jan 2013
    • 4
    Ps. I've tried another modem and its the same, it's bt Internet .
    • thepopes
      • Feb 2013
      I have a skybox f3 and need help
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        1: Hi! welcome to DK
        2: Please start your own thread. Hijacking other peoples is considered bad form.
        3: When you start your very own thread, please make sure to give as many details as you can about your problem. Help us to help you yeah?
        4: did i say welcome?
        5: if i didn't, welcome, and hey you, thanks for coming
        • nibblitz
          • May 2010
          • 1300
          There no reason it should do that.... Unless....
          What type of cable have you used exactly, What socket have you plugged the cable coming from your box into, and what device is this socket on?
          • lammylee
            • Jan 2013
            • 4
            Hi, it's an Ethernet cable connecting the f3 to the modem via the Ethernet plugins on the back of the modem
            is a bt home hub 2. Thanks lee
            • pspmixer
              • Jun 2009
              • 750
              view my thread on f3 help try that
              • damiensk
                • Apr 2010
                • 201
                presume you mean router and not modem.
                it wont be the internet, you might need to go into the settings of the router.
                does the wireless light go off on the router, when you turn the box on??
                • nibblitz
                  • May 2010
                  • 1300
                  Thats the correct way so...
                  Theres no reason why it should do that, your Skybox should not be the cause... Does the Skybox connect to your network ok and work properly when connected via ethernet? What if you plug something else into a LAN port on your Homehub instead of the Skybox (like a PC, Laptop) do other wifi devices still lose wifi when that other device is connected via ethernet? Maybe summats wrong with your Homehub...
