skybox f5/f3 wifi set up
  • princecarroll
    • Jan 2013
    • 60
    trying to set up dongle for both boxes.wifi ,active ,manager opened,my server found, input my password ,press ok, but does not connect .Encrypt mode WPA2PSK_TKIP. Any help would be gratefully accepted
  • togznstyle
    • Dec 2012
    • 166
    Tbo i would not use wifi as you will not be able to use your pvr setting for pausing and recording on to your usb i would stick you wired connection to your router just imo.
    Never eat yellow snow
    Don't forget to thank me
    TOGZ
    • Mysteriousguy
      • Aug 2012
      • 56
      Hi mate,
      I had a similar problem when I 1st attempted to connect.
      It was only after I changed the encryption method did it work.
      I use Wireless on my F3 & F5 box, no problem at all, as my router is not close to the box for wired connection.
      • princecarroll
        • Jan 2013
        • 60
        Originally posted by Mysteriousguy
        Hi mate,
        changed from 1 and 2 to just 1 and away it goes ,thanks
        • sb18180
          • Sep 2012
          • 355
          if you usin vermin superhub wpa2-psk[aes] is the setting you want.
