TV LISTf3 to f5
  • princecarroll
    • Jan 2013
    • 60
    TV LISTf3 to f5
    how can I use my tv listings, downloaded from my f3 ,to upload to my f5, it says the file is a mismatch. Can i change it so as it can read it. Tried ajs list but still some channels missing.This problem could stem from the fact box seemed set up for Asia.blind scann will get me most sk y ,but sone hd missing. Any help would be great,thank you in advance.
  • bigalan
    • Apr 2010
    • 34
    nut make shure the name is right it shud be TP_PROG.dbs befor you uplode it to the f5 and make shure your just dumping the chanle list and not the firmwhere
    • DW190
      • May 2012
      • 1263
      Put usb into F3 box with good channel list and DUMP the TP Prog from the Misc menu. Then you can upload the list to your F5.
      If you use a blank Mem stick you cannot make a mistake.
      • princecarroll
        • Jan 2013
        • 60
        No mistake ,it worked,satellite list and channel list all good.But with same connection's used for my f3,when placed in my f5, with new satellite list and new channel list installed , channels which worked on the f3 do not work on the f5. ? syk movie ch, irish ch, eden hd,these are some of the channels missing.This box seemed to have been set up for Asia. Where am I going wrong and can it be fixed?
        • DW190
          • May 2012
          • 1263
          Try dumping your F3 image file including all settings and upload it to your F5
          • princecarroll
            • Jan 2013
            • 60
            when dumping my f3 image file including all settings, what does this do to my f3,I mean will my f3 still retain it set up or will I have to upload it back from the usb stick to get it back to its original working state.
            • DW190
              • May 2012
              • 1263
              It will still retain setup. It just copies to the usb.
              When you upload to another box you can retain the box settings and channel data by selecting yes or have the settings from your copied by selecting no.
