skybox F3 - add sats eutelsat 16e/Hotbird 13e
  • beggsy21
    • Sep 2012
    • 76
    hi, i have a F3 running aj's channel list and all is fine. I have a second dish pointing at 16e (Eutelsat) which I was going to plug into my F3 as my current line supplier has given me a line to open the channels at tring/digitalb etc on 16e. Is there a channel list I can put in the box which will search the 16e sat & its tp's? Or do i need to manually add the satellite and its details?
  • nibblitz
    • 1300
    Its quick and easy enough to add a new sat, in satellite list press the button to add, then all you have to is it give it a name, put in the position, make active, then set the LNB to universal 9700-10600, reboot, and then blind scan that sat...
    • beggsy21
      • Sep 2012
      • 76
      spot on m8, many thanks.
