Homeplugs
  • jandial
    • 84
    Homeplugs
    Hey everyone. Just wondering if anyone can help me? I was looking to set up my f5 using home plugs. I currently have my router next to tv but I have to move it. Could anyone advise on a good set to get? Also how many OUTPUT plugs can be added? I have 2 boxes which I would like to hook up...
  • bbb_uk
    • 429
    Are the two boxes in same location (ie same mains socket) if so you will need one homeplug that is multiport (I have one that has 3 ports).
    If its going to be a different location (ie different mains socket) then you will need 3 homeplugs.
    I have solwise homeplug 200AV series and don't have a problem at all. However, I have only tried that and there maybe others that are cheaper and just as good.
    • mezzyg
      • Apr 2010
      • 158
      As above, I use tp-link ones, there pretty good and reliable.
      Sent from my Nexus 4 using Tapatalk 2
      • fazz69
        • 160
        i use Vonet bridge dongle, there bout ?15 each, and r very good.
        i had a set of homeplugs but they kept loosing connection at times.. TENDA Bridge is ment to be good..
        • jandial
          • 84
          The 2 boxes are in different locations. Is it just a matter of getting a second output plug or third if need be?
          • jandial
            • 84
            Can you just add a second plug to these for output?
            • pspmixer
              • Jun 2009
              • 750
              i use bt ones and there already pair togther so dont have to pair just plugged in and connected up
              i have four around the house
              one to my router rest to boxs all work fine
              • happy_highlander
                • Aug 2010
                • 3535
                Tp link 200mb version for me 3 of them and they work perfect
                • jandial
                  • 84
                  Is there input/output of these or are they all the same?
                  • happy_highlander
                    • Aug 2010
                    • 3535
                    They are all the same. I bought the pa211 starter pack them an extra 1. They are also reported to be compatible with the 500mb version.
                    • jandial
                      • 84
                      I think the 200mb ones will be more than adequate.. Cheers for ur help
                      • bbb_uk
                        • 429
                        Cheaper getting a pair of homeplugs and then an extra homeplug. The pair will already be paired so you just pair the 3rd one. You may be able to get packs of 3 which hopefully will be paired. You are correct 200mb is well more than adequate.
                        Like I said, I use Solwise without a problem and I know someone who uses TP link ones without a problem.
